RCU Forums - View Single Post - plane climbs at full thottle
Old 08-29-2003 | 04:40 PM
mouraneto
Default plane climbs at full thottle
I would add some shim under the top side of the motor mount to get some down thrust. The way I see, if in the exact moment you cut the power the plane tend to go down, even though it still carries some momentum (airspeed), it should be a engine thrust issue IMO.
