RE: New Giant GP Super Sportster!!!!!
Generate heat? You're kidding, right? On a run-of-the-mill sport setup?
Using 6 Volts on a servo is not a big deal. Sure, it increases the speed, but the JR servos I use - both digital and standard - are made to take any increased heat the 6 Volts might generate, which, I might add, is precious little. I doubt that the servo life difference would even be worth measuring.
You're talking high-tech and high-spec, listing credentials like you're vying for a job. Why?
Gsxphil is a guy who came in asking a simple question, hoping to get some good, clear information to help him steer clear of any potential brownout situation in a modest, standard setup in a sport plane. All he needs to know to do so is to keep his voltage above the brownout voltage. Good voltage and plenty of mAhs = no brownouts.
All this other stuff is just confusing the issue.
Jim
