BeastX Flybarless System and 5-Blade Main Rotor heads?
Hi Guys...
Looking to get some good advice on equipment i am looking at for a Scale Hughes NH500E project that i am starting. I have been reading up on scale builds but a little confused with "Phasing'.
However, i have come across some comments on the use of Flybarless Gyros/Stabilization Systems that take the work out programming/mechanical adjustments for multi blade heads.
Which leads to my question on the use of the BeastX Gyro. Can it be used with 5-Blade systems?
I intend to put this on both (1) a 600 size CNC 5-Blade main rotor head as well as a (2) 500 size CNC 5-Blade rotor head that i saw on the RC_Aerodyne website. I am also planning to use the semi symmetrical 500 and 600 scale rotor blades that are flat bottomed.
Appreciate any help i can get to clarify the above. Thanks!
Regarsd
Rush
