RCU Forums - View Single Post - Cross Trim (Anyone using this feature)
Old 11-03-2011 | 06:23 PM
Jack Diaz
Default RE: Cross Trim (Anyone using this feature)
Countryboy,
I don't know what radio you use. If it is a JR 12X, the LTRM/HVPT mini switch on the upper left hand corner of the throttle gimbal can be programmed as elevator trim.
It can be used in conjunction with the regular trim. So, depending on your preference or situation, you can trim using either one.
Jack
