RCU Forums - View Single Post - Cox .Pee Wee conversion
Old 11-03-2011 | 06:39 PM
Dr Kiwi
Default RE: Cox .Pee Wee conversion
The standard rule of thumb would say 40W... but you'll probably be using a far larger diameter prop than the PeeWee could run, so you'll have a lot more "effective" power..... unless you need a speed demon... and then you'd went a high Kv 40W motor with a PeeWee-sized prop on it!
