RCU Forums - View Single Post - Pattern wings
Old 11-04-2011 | 11:05 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: Pattern wings
ORIGINAL: TimBle
sure,wouldbe an excellent service. Would you ship worldwide?
I can't see why that would be an issue. I'm coming up with a form of information that I would need for this to work. Things that I would need from the customer are the wing planform showing aileron cutout, wing tube placement, wing tube length, wing adjuster position, fuse curvature. I would also need the actual wing tube to make the sockets from so we end up with an exact fit. To properly fit the fuse, I would angle the root rib slightly the run the sheeting out past the root rib about 1/4". The end user would then sand away the excess sheeting until a perfect fit to the fuse is accomplished. I would also need servo info so I could size the servo mounts and hinge preference. I'm sure I will think of more as this becomes a viable project or not.
