ORIGINAL: Dr Honda
I run 2x 2200 mah packs... and after 4 flights, and some messing around on the ground... I only put 400 ma back into each pack at the end of the day.
FYI... This is on a falcon with 10 servos, and there is a third battery pack for my engine ECU.
Well, that's 100 Milliamps per flight... and with 10 servos? I know you're an electrinics wiz, but to me, that's tough to swallow.
.... Are you doing just take-offs and landings per flight??
