RCU Forums - View Single Post - What are boost tabs???
Old 11-05-2011 | 06:29 AM
  #62
Rodney
Default RE: What are boost tabs???
ORIGINAL: gerryndennis
ORIGINAL: Rodney
Unless someone is redefining the definitions of ''balance'' and ''boost'' there is no similarity between the two. Balance meaning to have equal force about a pivot point, boost being an augment to the applied force. In fact, most boost tabs will be counteracting to balance as they usually contribute more static unbalance to the assembly as they are adding mass aft of the hinge or pivot point. There is also a difference between static and aerodynamic balance and either one or both can be accomplished with different implementation of structure. For instance, static and aerodynamic balance can be obtained by properly weighting the area ahead of the hinge line where that type of balance is implemented.
Rodney,
Aerodynamic 'balance' and mass 'balance' are two different things.
Exactly what I said, you are just confirming it.
In aerodynamics, control 'balance' refers to the force required to move the control surface and how that force varies with speed, deflection, and G force (there's more). We are discussing tabs that affect this balance hence balance tabs. I agree thats not quite the same as balance about a pivot (see saw or teeter totter?) balance
Mass 'balance' is about balancing the control surface about the hinge ie pivot line. This is mostly done to prevent flutter.
Again, exactly what I said except I did not mention flutter. Incidentally, while mass balancing my prevent the onset of flutter, it does nothing to prevent it. The flutter characteristics (susceptibility) depends more on mechanical structure as you want maximum stiffness with minimum weight. Anything will flutter given the proper stimulus, what you strive for in aerodynamics is to keep that frequency of susceptibility outside the range you will be operating in.
Confusion can arise because a common method of aerodynamic balancing, the horn balance (eg the top of a cub rudder), is often used as a good place to install the mass balance weight. The mass is there to prevent or reduce flutter, the horn is there to reduce the control force.
You can't change the aerodynamic balance with weight.
Dave H
At no point was this suggested or implied. You can do both at the same time however when you use the mass in front of the pivot point to equal the mass aft of the pivot point while controlling the ratio of the area ahead of the pivot point relative to the area aft of the pivot point you accomplish both tasks of static and aerodynamic balance.
