The best 4 stroke
William, Is the gear lash problem caused by failing to put the correct gasket under the cam housing? I think I read a post by you about that?
How does one identify if their engine is of the latest design?
I have a used Saito 80 that I plan to disassemble for cleaning, bearing change, and maybe a new ring. Hence my curiosity.
Thanks for all the info.
