RE: TMMY Scale Composites 35% scale Cessna
Adrian,
The fins have been sanded with 320 grit wet or dry paper and can be painted if you choose.
They also can be sanded with super fine paper (1000-2000 grit)and polished smooth with no paint, or just installed as is.
You can use white silicone as a gasket or filler to fill in the gaps left by the curve of the Vertical Stabilizer.
If you want the fins to be easily removable, just tape some plastic food wrap to the Stab before applying the silicone to the fin base, screw them on,
then wait a day for it to dry and remove the fins and the plastic wrap and reinstall.
Dan
