RCU Forums - View Single Post - SD-10G Issue With TX Battery Voltage
Old 11-07-2011 | 06:31 PM
F.Imbriaco
My Feedback: (56)
Default SD-10G Issue With TX Battery Voltage
The LCD Display overview on my radio shows a fluctuating voltage read. Never happened in the past as far as I recall. Specifically, after a proper fresh charge, the LCD display reads 8.1v and a second later, reads 7.2 v and then it bounces up to 8.1v or 7.6v or 7.4v. After two -three flights, it dips lower which is to be expected, but fluctuates as before to levels I'm uncomfortable with.
Then I stop flying.
At first, I thought it was the original battery, so I changed it to a low time 6 cell 2000mAh Eneloop .
Same voltage irregularities.
The radio went back to Airtronics late last year for the recall/upgrade of the circuit board.
