RCU Forums - View Single Post - Engine placement.
Old 11-08-2011 | 05:29 PM
luciuswillson
Default RE: Engine placement.
Thanks SeamusG:
I think that is where I was going wrong. I was thinking I was supposed to mount the mounts the the horiz line in the middle of the two raised lines. Thanks for your help.
ORIGINAL: SeamusG
If you mount your engine upright, on top of the rail (red arrow orientation), then the mount should be aligned so that the raised bit pointed to by the red horizontal arrow should be aligned with the firewall "center line". If you mount the engine inverted, on bottom side of the rail (yellow orientation), then the mount should be aligned so that the raised bit pointed to by the yellow horizontal line should be aligned with the firewall "center line".
Yea, yea - clear as mud.
