RE: The new Tornado sport jet
Balancing via weight on the nose will only be accurate if everything is identical on Henry's plane and yours (ALL landing gear geometry: strut angles, length, wheel size, crookedness of the blocks the gear is bolted to, etc...). If anything is different, you must compensate for it.
Now close is likely good enough, but measuring the actual CG location is always best!!!
