ORIGINAL: megafly
Cg location in the manual ''CG Location- 12 3/4 inch back from the leading edge measured at the wing root,'' is wrong! If you balance that way the plane is going to be very nose heavy.
Megafly I wouldn't say its wrong, its just conservative, the Tornado is intended to bring new jet flyers so you don't want a new pilot with a Tail heavy Jet once you get used to the jet then bring the CG back to your likings.
