ORIGINAL: megafly
Cg location in the manual ''CG Location- 12 3/4 inch back from the leading edge measured at the wing root,'' is wrong! If you balance that way the plane is going to be very nose heavy.
13" works very well for my Falcon, so it can't be very nose heavy if balanced at 12 3/4", that 1/4" difference won't make too much difference. I have no problem at all slowing down or loosing elevator authority at low speeds so I'm definately not nose heavy.
