RE: The new Tornado sport jet
Our Tornado came out at !7lbs dry with the UAT full. We balanced it at the 12.75" dim. listed in the manual. We double checked the nose gear weight and it was 1.8lbs. Had we used the 1.5 lbs, we would have been tail heavy. The 1.5 lbs will only be accurate if you have the same emty weight as the Modelbau listed emty weight. At 12.75" the balance is perfect on our Tornado.
