ORIGINAL: rlipsett
just to put my two cents worth in the servos in the tail can be synced up using hitech programmable servos and a programmer to set the center and endpoints.
True, but most likely the OP does not have either. And it will work on centers and endpoint but what about the rest? I dont know about you but when I fly I usually use the full range of rudder and not just center and endpoints.
