ORIGINAL: BarracudaHockey
Yes, you can synch them up.
But unless you have programmable servos, a programmer, and a need to have weight in the tail, I wouldn't bother.
You can MATCH center and end points only. They can not be put in sync. This was cut and pasted directly from Hitec's site. However, I do agree that unless you need a CG shift stay with pull pull.
<div id="main_text"><div>Programming your servos has never been easier… or so affordable. The HFP-25 Digital Servo Field Programmer and Tester. With its lightweight, streamlined case and rechargeable NiMH battery pack, is a must have for all hobbyists looking to program Hitec's HS-5XXX and HS-7XXX series of servos. The easyto-read LCD screen, low battery warning and both manual and automatic testing capabilities make this programmer our best ever.</div><div>Get more! Get Hitec!</div><div>
<font size="4">Features </font></div><div>
Programmable Features Include:
</div><ul>[*]Reset to factory default[*]<span style="color: #ff0000">End and center points </span>[*]Direction of Rotation[*]Dead Band Width[*]Failsafe Point[*]Speed (reduction only)[*]Overload Protection (HS-50XX & HS-7XXX Series)[*]Resolution Mode Setting HS-7XXX Series Only)[/list]</div><div><div>
<font size="4">Product Downloads</font></div><ul>[*]
HFP-25_Manual.pdf[/list]</div>
