RCU Forums - View Single Post - Pull pull vs. push pull
Old 11-10-2011 | 12:17 PM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: Pull pull vs. push pull
Unless you have a geometry problem, then matching the center and end points should be enough to synch the servos.
I've done it before for someone, we used a programmer and went back with an inline amp meter to make sure the current wasnt spiking up anywhere indicating a bind.
