Thanks Kevin,
I was thinking 1:1 as well. I am not sure what the 38 lb is in the attached pic pertainsto for sure.The way it sounds is that this plane is 38 # on the high end. Iam thinking that I may be able to build this less than 38 pounds though. Ideally 30 dry (including engine)
Andy
ORIGINAL: kevinthoele
F16's fly great in all sizes. At 38 pounds I would not use less then 30lb engine. The K 170 at 37 pounds for around $3K sounds like a good fit.
