RCU Forums - View Single Post - Pull pull vs. push pull
Old 11-11-2011 | 05:51 AM
rlipsett
Default RE: Pull pull vs. push pull
you have never dealt with hitech programmable servos. you program the servo itself. you can set the centerpoint anywhere in 360 rotation so the centerpoints of all servos would be spot on. you then can set how many degrees you want to rotate, I believe up to 180 degrees lock to lock but the resolution suffers past 120. the programmer does not remain in aircraft, unlike a servo mixer
