RE: Radio Choice
Isn't the AR6200 the RX without the remote antenna box? On those if you don't set the antenna just right you can lose signal to it. They work great in foam fuse planes, and in fuses that have open spaces under the covering, but not so well in solid wood fuselages, and dont work well at all if there is CF in the frame. I have one in my Apprentice, but my T-34 has an AR6210 with the remote box on it. I don't think I would trust the AR6200 in any solid wood fuse only due to the antenna placement, if you dont get it just right, you could drop signal at certain angles.
EDIT: Went to my planes, the Apprentice has an AR600, I thought it was a 6200. Are you guys referring to the AR6210?
