RE: Its been a while RCU.. Help me rebuild my truck
Heh go for it, I've never seen a Collari .30 run in person but they seem like decent engines- pretty expensive if I remember correctly. Yeah I hear ya, personally I like the older style trucks better- more proportional IMO. If you mean on the FLM plate- then its no possible cause theres actually no brace for the rear facing part of the plate- just 2 stub mounts. On The stock setup the cracks are occurring on the rear lip where I ground off the notch to clear the diff outdrive- I'd imagine its making contact with the diff outdrive whenever theres an impact on the engine and thats the reason for the crack. I could enlarge the notch, but its already close to the engine mounting surface and the plate is only 2.5mm thick- its asking for trouble.
