RCU Forums - View Single Post - Modelbau MB339 buildout
Old 11-13-2011 | 07:12 PM
InboundLZ's Avatar
InboundLZ
My Feedback: (10)
Default RE: Modelbau MB339 buildout
Continuing with the mount.
Picture #1 shows the front bulkhead in place with the two motor mounts and a third spacer to align the forward bulkhead. The actual motor mounts are not glued in place at this time. I will place them in position once the bulkheads have cured in place (over night).
Picture #2 shows this from a different view.
Picture #3 Shows the motor mounts in place. Again I used mu laser system to zero the air frame. I then shot a "line" from behind the jet up the tail pipe. Centering this line in the exhaust exit I was able to get the engine right on the thrust center line. Sweet!
Picture #4 is another view...if you look closely you will see nice clean hysol fillets....
ID:	1686394   Click image for larger version
ID:	1686395   Click image for larger version
ID:	1686396   Click image for larger version
