Will this setup work? Need Advice Please
Lobo, it looks like you've done some excellent research.
Your choice of tx is an excellent one. As far as rx's, either rx is excellent. The Berg 5 is my choice of rx, and is the most solid one I own, including my full size JR and Airtronics rx's, I don't own a 555, but I hear they are also a very solid rx. The berg should come with a crystal, I don't know about the Hitec, but it wouldn't be hard to find one. Your issue with ch5 on the Berg is a common issue, and it can be done fairly easily. I'll see if I can find the info for you.
If you want flight time, Li-poly's are what you're after. I'm still learning about them myself, so I can't give advice on which one to use.
I'm not very fimilar with the MKII charger, but if you're going to run Li-poly's, it may be worth your while to get a good quality li-poly charger.
Hope this helped.
Jason
