ORIGINAL: Foxy
Cool. Will it take fatter 3s batts?
It can if you cut off the outer edge of the battery tray. Its actually just two small pieces. No dremel required. The plastic is soft enough for lexan scissors.
Homey55,
you can do the same thing I suggested to Foxy for your lipos. Then use velcro to keep them in place.
Shark,
I shared your pov before this buggy was produced. You should take one for a test drive sometime.
Now if only Xray would produce a 1/16th mini 808 that would be killer!
