ORIGINAL: Numbness
Does that mean that the rods need to be bent exactly to match? Is there some kind of lubrication I should grease up the pushrods with?
If the rod is too strong, it may take some force to be bent while it slides back and forth.
Both solutions should help (silicone lubricant), plus reducing the diameter of the steel rod or switching to a cable.
