RCU Forums - View Single Post - OS 46AX engine test
Old 11-15-2011 | 02:47 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: OS 46AX engine test
I've had 4 OS .46AXs and still have 2 of them. Outstanding engines.
It sounds to me like it is too wet when you start it. I hand start all my 2-strokes and have never needed a starter on the AXs. Choke your engine as you normally do and turn the prop so the piston it up against compression where you normally would flip start it. Hook up the glow ignitor and take the spinner with your right fingers and snap it backwards. The piston will go down, then back up and hit compression as if to start backwards. Since the cylinder is a little wet from the prime, it will fire prematurely and start forwards. If you don't have a spinner, spap the prop backwards. I use a glove. In no case should you pull the prop through compression and top dead center. To do so will cause it to fire backwards and attempt to get your finger.
Set the high end needle to peak and back off 4 clicks or more. Idle down and time 30 seconds, then pop the throttle to full power.
1. If the engine rumbles and blows smoke, it is too rich.
a. Close the low end down 1/8 turn and try again.
b. Keep doing this until you can go from idle to full power without and stumbling.
c. At the end of your adjustment you may need to turn the low end adjustment only 1/16 turn.
d. It is better to be slightly rich than to be a little lean on the low end.
e. As fuel burns down in your tank, the engine will lean out slightly and you don't want it to overheat and kill a glow plug.
2. If the engine coughs and spits, it is too lean.
a. Open the low end adjustment 1/8 turn and try again
3. This takes a while so don't be rushed.
4. I use 10% Omega, castor blend for my OS engines. It is my opinion that the ABN, nickel plated OS sleeves need some castor oil for long life.
5. I like the OS A3 plug. It is now called the OS #6.
6. An 11-5 is my preferred prop for sport flying on my OS .46AXs. It revs up good and pulls well.
