RCU Forums - View Single Post - Modelbau MB339 buildout
Old 11-15-2011 | 11:56 PM
InboundLZ's Avatar
InboundLZ
My Feedback: (10)
Default RE: Modelbau MB339 buildout
OK Back to work!
Like I said, getting the wing mounted is what set everything in motion....
Ok, I decided that I want to use a pin and bolt system like I have on my CompARF Flash. So the first thing I needed to do was make some pins. I know some guys used wood dowels but I felt that they might not be strong enough so I built my own composite dowels using a carbon fiber tube and some hard wood dowel material. I then mated them up with a 1/4 ply circle that will back up the pins once they are installed.
Picture #1 & #2 Shows the pins
Picture #3 Shows the large holes in the forward bulkhead.
Pictures #4 & #5 show the hold down dowels installed in the wing.
ID:	1687259   Click image for larger version
ID:	1687260   Click image for larger version
ID:	1687261   Click image for larger version
ID:	1687262   Click image for larger version
