RE: Pass Port
I would use fixed end points. The instructions on setting them up are attached. Set it as outrunner mode and I would leave the brake off at first and go from there. After you get some flights on it you can start playing with the brake, but I wouldnt go more than 30% as you can start getting some weird noises coming back up on the power.
Arch
