RE: Pushrod binding - help!
It's not needed. If you're setup is right a smooth wire should slide well enough in a smooth sleeve. The nyrod really is the best solution when you have to go around some turns. Just anchor the sleeve in a couple of places along the way and you're done. If you're getting serious bending at the servo, the anchor point is too close to the servo.
