RCU Forums - View Single Post - HELP!! Please Read This
Old 08-23-2003 | 10:53 AM
wmueller10
My Feedback: (22)
Default HELP!! Please Read This
Since you need only one piece of tubing, you might be able to get away with this idea and get you back to your Saturday schedule.
Buy a standard size Aluminum tube (your local hobby store) and shim it with paper. Then saturate the paper with thin CA,,, need it stronger, use epoxie or JB weld.
K&S Round Aluminum Tube 3/8x36" .016 (4)
Special Stock# LXRW78 Towerhobbie's Price 10.99
Tower has 3 different wall diminsions in this size (3/8" )
Any machine shop could make that tube,,,, not a difficult task at all,,, they probably didn't feel like setting up on that small job. The machine shop would need a 8mm expanable reamer, thick walled alum tube material, then turn the OD down to size,,, estimated time on set-up and execution, 1 hour,,, Price, $50 for that tube!
Decimal conversion; (Standard Size)
8.225 mm = .323 ths ID (5/16" = .312")
9.825 mm = .386 ths OD (3/8" = .375")
150mm = 5.900 ths Length (5 29/32 inches)
Hope this gets you going again, Willi
