ORIGINAL: sharam
The finish is very clean, albeit too shiny; nothing that some flat clear coat won't fix. I also got a DLE 20 cc from Tower for this bird. Looking forward to getting this done!
woot
Sharam
If you coat it you will not be able to use covering iron, e.g. for wrinkles.
I have the same covering on the VQ FW-190 60, and used scotch-brite to scuff it up and some alcohol to remove the shine and get some weathering effects.
