RE: JetCat V10 ECU
John, with the LiFe batts and the V10 ecu is it ok to splice in a charge port on the batt leads and leave the battery plugged into the ECU to charge. Since the Lifes use a cvcc charger I would assume this would be Ok? I have all the turbine equip stuffed as far forward in the Migs nose as possible for balance. Scotty
