RCU Forums - View Single Post - Converting 2 stroke to clockwise rotation
Old 04-17-2002 | 03:19 PM
ChuckN
Default Converting 2 stroke to clockwise rotation
You will need a crankshaft that is machined with the intake port in a different location so that the intake timing is correct. On engines with a removable front plate like the K&B 3.5 or the O.S. .25VF you can rotate the front housing 90 degree and accomplish the same thing. Unfortunately, you can not rotate the front of your O.S. .25FX.
