ORIGINAL: rowdog_14
Well I purchased some new fixed landing gear from tower hobbies because I thought that was the problem with the plane leaning on taxing and landing. Come to find out the landing gear are not flexing that much it is the actual tires that are rolling over the rim causing the plane to lean really bad on taxing and landing. I purchased the Dubro threaded lightweight tires. What tires are you all using because I have to get another set before I start flying this plane again, because if I do not I will not have any flaps or lower wing tips anymore
Rowdog
I have both the kit fixed gear and the kit wheels. If you want them, drop me an Email w/ an address and I'll send them off to you.
Al
