RCU Forums - View Single Post - 180FS Glow to Gas
Old 11-18-2011 | 10:40 AM
  #81
dogshome's Avatar
dogshome
Default RE: 180FS Glow to Gas
Solved.
It was the ignition pickup being slightly too far away.
Spring in carb definitely not required with pipes from the crankcase breather via carb to manifold as shown
20/64ths without accelerator pump idles very well, but has to be set too rich for a good transition. The other engine WITH accelerator pump (and larger bore) does not suffer this problem.
I'll try a smaller carb, but I am sure it will restrict revs. I have a tacho these days!
