well CG personal pref ..
what i would do is a basic trim set up so like many others you can use mixes . first CG trim I'd set up my plane to flight a inverted flat line with natural trim other words hand's off vary little decent or Clim
second airlon diff up line with the least amount of wind affect possible doing Axel roll to the right and to the left you'll find out mid wing's don't use alot of differential
make sure to check your thrust angel with a vertical line also . check your rudder with a power off straight down line again least amount of wind affect possible
knife edge mixing use the P mix in your radio start out with a small ratio and just keep flying knife edge passes from right to left .. left to right and add percentages via mixing in elevator to rudder to get a hand's off knife edge for a exmaple i have 4 precent elv to rudder on my p mix .. some time you might need to add airlon into the mix if you have alot of toqure affect
but after going thought all the mixes all the set up . then you have to get your mind use to the model stick time
edit roller's aren't easy if you are off you should maybe look up some of josh's clinics and spin more time in inverted harrier and up right harrier figure 8's
also try use differnt rat's or servo speeds if you get a crazy fast servro with a giant airlon , it's not going to be vary easy to stay on top of the transition even with pilot's that can do roller's on there own plane they can't just jump into someone else's plane set up different and go right to a smoth roller the timing is going to be a issue.. ( atleast most the truely talented and blessed one's have the speed and smothness to do it )
http://www.youtube.com/watch?v=JBdh9...eature=related
