RCU Forums - View Single Post - 180FS Glow to Gas
Thread
180FS Glow to Gas
11-19-2011 | 10:24 AM
85
CH Ignitions
My Feedback: (
11
Aug 2009
399
West Palm Beach, FL
RE: 180FS Glow to Gas
Hi Rick,
Here are some close up pictures of WT-37-1 that I think is absolete and hard to come by.
The governor is good but not for us we want to go hi RPM's not to throttle back.
The stuff I made is real hard to see in one of the pictures ...is on my tumb were the governor can be seen.
You screw it out, make a small round piece or you can solder shut the hole the is on the side of the governer
in the grove . But then will be hard to revert back later.
As far as intake...I do not know if you refere to mine or not but mine is simple. Instead of going outside and have a tube and more work....
I just went inside.
And here is a list... PDF of all carbs that MYWIFE !!! Camelia put together for me. All barrel carbs and butterfly WYK and WT from the smallest to 12.2mm venturi.
Where you see no price...is no longer available. On WT series all carbs that have ACC Pump if say no does not have it but my worth to try. On WYK series are all carbs that have both needle LO/HI. So she did this in 2 days. over 1000 carbs that she went trough.
Thank You
Adrian
Co80369.pdf
Reply
Like
CH Ignitions
View Public Profile
Send a private message to CH Ignitions
Visit CH Ignitions's homepage!
Find More Posts by CH Ignitions
View iTrader Profile
