Originally posted by justgotr
here's what i have understood from the guys that help me put my planes together...not sure if this is the answer...when you set the CG you do it with an emepty tank,so if you run out then you are still nose heavy alittle..if you have fuel in tank and dead stick then you are still nose heavy...if tank was at or behind CG then if you dead stick then you might end up tail heavy, which i hear is no fun to fly....i hope this made since....i'm still learningso dont take my word for gospel...spooner
Absolutely right!
Also, if the CG moves slowly back in flight the plane becomes a little more sensitive, which isn't such a bad thing, as by then, the initial shock of getting used to it has died away a bit!
Also, landing becomes a little easier, or slower, as the plane floats a little more when the fuel has gone.
-David C.
