Originally posted by JohnBuckner
David that would be an interesting experiment if you were doing it for the purpose of providing different stability levels to match various manuvers. But if you are doing it just to compensate for the rearward march of the CG as fuel is consumed then it would be far simpler just to use a bubbleless tank centered on the CG, that will feed reliably from that position .
John
Agreed John.
My thoughts about it were more to do with the fact that I seem to plan to try moving the CG back for the next time I fly, just to see how the handling is affected, but never seem to get round to doing it! Having a system that can be adjusted on the spot might help that situation.
I was thinking of doing it with my Edge, with a YS110 in it, so the fuel tank position, with respect to fuel suction isn't really an issue in the first place.
-David C.
