ORIGINAL: Ernie Misner
Hmmm, you should start a new thread in the engine forum about that front bearing / seal leaking........ how important that actually is, and why that is not affecting the top end as well .... ?
Also, being a true ABC type engine, does your GMS still have a pinch at TDC when cold? Just curious.
Ernie
Do I sense a bit of sarcasm here? Not sure I want to open that can of worms. Yes, the engine does have a pretty good pop at TDC when cold. I'll try putting it back on the airframe and futher tweaking the LSN and see if it makes a difference. Thanks again, everyone, for the comments so far.
<br type="_moz" />
