RCU Forums - View Single Post - KingTech K-80
Old 11-20-2011 | 10:02 AM
  #819
essyou35
Default RE: KingTech K-80
Hey guys, when it said full power I was putting the trim to max too.  Realized that is wrong.
I used a 7.2 lipo now.  Here is what it does:
Put trim to nuetral, it says ready.  put stick to max and it spins up into a cooling cycle?
Go to stick low and it starts.
It goes through it stuff, but the burner tmpe is abou 14C, never gets higher.  The pump makes some odd noises, no fuel flowing.
I did a fuel pump test and it shot fuel ouit like crazy.
Tried to start 2 times both took about 2 mins then said ignition failed.
I am using a k80F.  SHouldnt the burner temp be getting up there pretty good?
