RE: Special Tools Any Others Bought or Made?
Hot wire bow cutter made from a piece of ABS hot water pipe. End braces are made from coat hangar wire. Cutting wire is .020 piano wire. This is strung like a real bow as, if you leave it strung, the bow loses it's tension. I have about half a dozen different bows and this one gets the most use, mainly because of its light weight. Very nice to handle.
