RCU Forums - View Single Post - KingTech K-80
Old 11-20-2011 | 05:06 PM
  #823
essyou35
Default RE: KingTech K-80
Complaints!!
The instructions for K80F do not exist, as a new user this is a major over sight.  This isnt rocket science but its not common knowledge the gas line needs to be kero.
The FOD screen requires me to cut holes in it for the tubes, which is moronic.  They should cut the holes and put bushings in there so metal is not shafing on the cheap lines they supplied.
The k80 comes with some super crappy fuel lines, lookes like aquarium line.  Does anyone know of an alternative that can be used?  Tygon wont work because of the fitting used due to the OD.
Finally, having to unplug these crappy lines from the turbine each time I want to run it is ASSININE
Also, not enough of the 4mm line came with it, I need at lease twice as much as supplied.  Then I have about 5 times too much 3mm line.
The GSU screen is worthless in the cold.  Come on its 2011, this is 1980s technology in there.  Hell I can get a program an LED screen for my arduino for a bout 10 bucks.  Somone desiging a GSU should be using a COLORED LED screen by now.    The cost would be minimal.  But they are making a killing of the GSU anyways, its about $5 worth of parts.
Ok done comlaining, now I am going to run it.  Lets see what its got.
