RCU Forums - View Single Post - Types of Webra 60 questions
Old 11-21-2011 | 11:00 AM
doxilia's Avatar
doxilia
Default RE: Types of Webra 60 questions
rreale,
I believe it is the more modern version of the 1030 or 1033 long stroke RE Webra. Webra started to make red heads later in their production. The 120 also had a red head. I'm not sure that it is a long stroke but I suspect it is as most manufacturers moved to long strokes later in production due to noise issues. But Jari might be right, it could be a "Racing" version for higher RPM than either the "Speed" or the "Competition".
Both the SE and RE engines could and were used in competition it just happened that Webra designated the SE versions as "Speed" while the RE versions as "Competition". Naturally the RE versions were used often in competition models as many of the pattern designs of the 80's used enclosed pipes with RE engines.
Perhaps the red heads were for racing events although I can't see what a Dynamix would do on one in that case. The Dynamix is a rather sophisticated carb mostly used in pattern. Some even had in-flight adjustable high speed needles.
Post some pictures!
Good to have another Canadian round this forum!
David.
