adding right thrust
Hi if the firewall doesn't have the right thrust built in then place 2-3 washers between the left side of the motor mount and firewall.
But check the plans and instructions carefully first and make sure of there intent.
They might want you to move the engine left to place the prop adapter on the centerline to counter the right thrust built into the firewall.
What plane is this?
