Degree of thrust
mstroth......ah ha! You was right on! After that last posting to you I went back and studied that tiny diagram drawing and it showed the the engine was slightly moved to the left and then stated to shim the mount and showed that the propeller adapter was in the middle of the front of the plane.
I suppose I should have studied this thing a little bit more before made postings, eh? Thank you for your help.
