ORIGINAL: FalconWings
Dude, seriously, if you have to ask you probably need new servos
Servos should grow old with your airframes.
You are right they should but if they die in the air then your Jet could die with it [&o] I have seen servos go bad plenty of times in other peoples jets in flight and always wonder if they check them on the ground before the flight.
