RCU Forums - View Single Post - Pass Port
Thread: Pass Port
Old 11-22-2011 | 07:35 PM
Don Szczur's Avatar
Don Szczur
Default RE: Pass Port
The setup works quite well. Joseph won the NATS in Advanced with a Passport and E-flight 160.
Here is the throttle curve that I set up for this motor. This provides a nice linear feel for the motor. Also, you will notice an 80 percent limit on the throttle curve at full throttle. This is to keep the noise below 92 dB over grass (prop is the standard APC 21x13.5)
Best regards,
Don
ID:	1690050   Click image for larger version
ID:	1690051   Click image for larger version
ID:	1690052   Click image for larger version
